I haven't seen Progress corruption but was able to fix Vantage corruption on
the JobAsmbl table with ProVision when Child/Next/BOMSequence fields were
corrupted. By the way, the V8 conversion can corrupt the BOMSequence -- it
renumbers the field producing duplicates in 6 of our jobs.
I don't understand why Epicor's solution wouldn't work on the normal Dump &
Load so you wouldn't have to buy ProVision. Maybe you could move the
corrupted tables to a different directory if the process would take too long
on all of them.
We use ProVision to update the database. It also provides a GUI programming
interface similar to Visual Basic that's much easier to program GUI than the
non-updating 4GL provided with Vantage. But beware of this powerful product
for without careful analysis, you can damage the database yourself real
easy.
on all of them.
easy.
----- Original Message -----
To: "Vantage@Yahoogroups. Com" <vantage@yahoogroups.com>
Sent: Tuesday, September 20, 2005 6:27 AM
Subject: [Vantage][5.2] dump and load problems
> I have some db corruption, and am looking for a 'workaround' to the
problem.
> Trying to "dump and load" the db, it produces an error on the jobasmbl
> table, but continues, and then crashes on the labordtl table. Looking at
> the 'vantage.lg' file, it identifies several recid #s that are problems.
> I'm thinking that running idxfix and removing those corrupt recid's might
be
> a possibility. Has anyone had a similar problem, and is there a fix other
> than sending the db to Epicor and "running on paper" for however long it
> takes for them to fix it and get it back.
> Epicor said to selectively dump and load the tables with Provision, which
I
> don't have, and then run a program they got from Progress that "might" fix
> the problem. We're debating spending $4000 for Provision, not knowing if
> will solve the problem.
> As a side question - those of you that have/use Provision, is it worth the
> $? What can Provision do for me?
> thanks,
> Norm Watkins
> Engineering Manager
> ELECPAC
> Phone: 847-639-2307
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Yahoo! Groups Links
