Thanks. That's what I thought but it helps to have a bit of confirmation.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ned
Sent: Friday, February 20, 2009 4:17 PM
Subject: Re: [Vantage] [6.10] _Mprshut.exe syntax to shutdown DB from command line?
My apologies, I need to read more carefully before answering.
-by
Directs Progress to perform an unconditional batch shutdown and to
disconnect all active users. Using -by in conjunction with -F causes an
emergency shutdown.
http://progress.atgnow.com/esprogress/resultDisplay.do?gotoLink=297&docType=1000&contextId=11530%3A297.464%2C356.464%2C419.464&clusterName=CombinedCluster&contentId=d56a84e5-71aa-4ef7-9d44-7479d27b6b1c&responseId=61e197040ff9ab04%3A1b1fbf4%3A11f9463a7dd%3A1a83&groupId=1&answerGroup=7&score=566&page=https%3A%2F%2Fprogress.atgnow.com%2Fesprogress%2Fdocs%2FProgress%2Fesupport.progress.com%2FEDocHTML%2FProgress%2Fspr%2FTOC.html&result=14&excerpt=Startup+and+Shutdown+Commands+Startup+Command+Syntax+2.2+Tasks+You+Can+Perform+With+Startup+and+Shutdown+Commands+2.3+Startup+and+Shutdown+Command+Descriptions&resultType=5000#Goto297
-Todd C.
-by
emergency shutdown.
----- Original Message -----
From: "Todd Caughey" <caugheyt@...<mailto:caugheyt%40harveyvogel.com>>
To: <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Sent: Friday, February 20, 2009 4:50 PM
Subject: RE: [Vantage] [6.10] _Mprshut.exe syntax to shutdown DB from
command line?
> Thanks but I don't think this will work on 6.10. But I will certainly
> keep it for when we get to 8 or 9.
> -Todd C.
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
> Of Ned
> Sent: Friday, February 20, 2009 3:28 PM
> command line?
> Here is the context of a batch file that assumes Vantage is installed on
> the
> E Drive.
> @echo off
> echo Stopping 8.03 Services and Database...
> set DLC=E:\Epicor\OE101B
> set PATH=%DLC%\BIN;%PATH%
> set LIB=%DLC%\LIB;%LIB%
> E:
> echo .
> echo .
> echo STOPPING MfgSys803 DB/APPSERVER...
> cd \Epicor\MfgSys803\db
> call asbman -name MfgSys803ProcessServer -stop
> call asbman -name MfgSys803TaskAgent -stop
> call asbman -name MfgSys803 -stop
> call dbman -host localhost -port 20931 -database MfgSys803 -stop
> <caugheyt@...<mailto:caugheyt%40harveyvogel.com><mailto:caugheyt%40harveyvogel.com>>
> To: <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>>
> Subject: [Vantage] [6.10] _Mprshut.exe syntax to shutdown DB from command
> line?
>>I use _mprshut to fire up Promon but I think it can also be used to
>>shutdown the database. Correct? If so what would the syntax be? I need
>>to automate a full shutdown of the server after tonight's backup so
>>accomodate a planned power outage in the whole building tomorrow morning.
>>I want to schedule a DB shutdown and then a little later will do
>>PSShutdown
>>for the server itself.
>> Thanks,
>> Todd Caughey
>> Harvey Vogel Mfg. Co.
>> [Non-text portions of this message have been removed]
>> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
>> have already linked your email address to a yahoo id to enable access. )
>> (1) To access the Files Section of our Yahoo!Group for Report Builder and
>> Crystal Reports and other 'goodies', please goto:
>> http://groups.yahoo.com/group/vantage/files/.
>> (2) To search through old msg's goto:
>> http://groups.yahoo.com/group/vantage/messages
>> (3) To view links to Vendors that provide Vantage services goto:
>> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
