Thanks Jill. Yes, I had verified the DB (it said it was up to date) and also checked the path to the .mdb file. Yes, I am linking the .dbf file (MTLTAGS.DBF) to the Access DB tables. For grins changed from mapped drive letter to UNC path on the tables - still error.
When I run without print preview it prompts for printer and says (briefly) it is printing page 1 of 1 before issuing the 533 error. So I think it has content ready but can't connect to the print driver. I vaguely recall a Progress Error 533 issue related to printing. I tried printing to Acrobat to make a PDF file and it got past where I name the file before erroring. I had also emptied the local work folder.
It works great when previewed in Crystal developer (on my PC) but not from within Vantage (also on my PC) which really makes me think it is a Progress issue and not Crystal, data or local .DLL files. I am wondering if there is a server involvement and I need a different version of something there. I'm shooting in the dark because I don't know what is happening behind the scenes when Vantage runs a Crystal report. The Printer Selection window though is showing as a Prowin32 item on the task bar so I know there is some Progress involvement.
I'll do some more searching on web for Progress and Error 533.
Thanks again,
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jill Seeman
Sent: Monday, August 30, 2010 6:11 PM
Subject: [Vantage] Re:[6.10] Crystal Error 533 - One for the old timers.
Hello,
Error 533 means BADDATABASEFILE Something is wrong with the database you have specified. You may need to verify using the Database|Verify Database command. I believe you can verify the db in Crystal from memory. Are you sure the locations of all tables and are correct? Are you using both Vantage temp tables and joining with live tables? Check with Set Location command in Crystal.
Hope this helps...
Regards,
Jill Seeman
Information Technology Manager
[Description: C:\Windows\65email.jpg]
615 Goodwood Rd Panorama SA 5041 I PO Box 18 Melrose Park SA 5039
t: (08) 8275 0233 f: (08) 8277 0229 m: 0434 071 027
jseeman@...<mailto:jseeman%40bedfordgroup.com.au> I www.bedfordgroup.com.au
Bedford - Creating a brighter future
Thanks again,
-Todd C.
Hello,
Hope this helps...
Regards,
Jill Seeman
