When adding the link table (right after the logon screen where you enter the password) before selecting the table to link to, look for a check box on the lower right that reads something like Save Password.
Â
When this box is checked then it will keep the login and password for the linked table.
Â
See attached screenshot.
Â
Â
--- On Mon, 2/9/09, Todd Caughey <caugheyt@...> wrote:
Subject: [Vantage] [6.10] ODBC File DSN Oddity with Access-2000
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Date: Monday, February 9, 2009, 1:25 PM
I'm extracting some Vantage data into Access tables. I'm using a File DSN which includes the username and password for the ODBC connection. When I add a linked table in the Access DB it works great. No credentials prompting. When I exit the database and then open it again I can't view records in that linked table without being prompted for user/pass. IF...I then add another table (once again selecting the DSN file) I can then immediately access that other table I had tried to open before and failed.
It is as if just refering to the DSN file provides the credentials for the rest of the session.
Anyone know of a way in a macro to hit the DSN file so that my Make-Table queries can run? I've got this all packaged in an AutoExec macro that runs when the DB is opened so I can schedule it to run the update everynight.
Todd Caughey
Harvey Vogel Mfg. Co.
