When I go to actions Lot numbers it pulls up the same old lot entry screen just as read only.
There are no lots listed in there for a part, I have to do a search to select the lots available for the part. 2 extra steps & the added functionality they are talking about is not even there, what an improvement. Am I missing something, I liked it right on the part tracker.
--- In vantage@yahoogroups.com, "Steve_E" <vantage@...> wrote:
> Summary: Part Tracker lot number information - 8.03.408 and later
> Book: Support Solutions
> Page: 10369MPS
> Problem
> Prior to installing the 8.03.408 Service pack, the lot numbers for my parts
> could be found in part tracker under a tab along the top of the screen. Now
> that im on 8.03.408 that tab is not there? Where did it move to?
> Resolution:
> This changed with the release of SCR 54063 on service pack 8.03.408. This
> removed the lot information from part tracker and part maintenance. The
> information can now be found under the actions menu inside part tracker and
> part maintenance. Inside here you now have expanded traceability with the
> lot numbers for that part. The new Lot tracker screen allows you to see Bin
> information, transaction history, and document links specifically for the
> lot number you have selected. You can also see the Expiration date, First
> Referenced date, and Last referenced date along with costing lot
> information.
> Steve
> -----Original Message-----
> From: Michael McWilliams [mailto:mmcwilliams22@...]
> Sent: June 02, 2009 10:55 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: 8,03.400 patch 408
> What do you mean by "moved" the lot number?
> --- In vantage@yahoogroups.com, "Steve_E" <vantage@> wrote:
> > What I am tracking down is that patch 408 moved the lot number and if you
> > have any BPM setup for the part method the system is hung up. I am
> > currently talking to technical support but do not have any resolution as
> of
> > yet. I have not tested it but if you remove the BPM from the part before
> > you do a conversion I would guess that there would not be a problem.
> > Steve
> > From: Ken Cary [mailto:kencary@]
> > Sent: June 02, 2009 7:59 AM
> > Subject: Re: [Vantage] 8,03.400 patch 408
> > Sorry, I don't Steve.
> > ________________________________
> > From: Steve_E <vantage@>
> > Sent: Tuesday, June 2, 2009 8:50:41 AM
> > Subject: RE: [Vantage] 8,03.400 patch 408
> > Ken
> > Do you have any BPM setup on the part method?
> > Steve
> > From: Steve_E [mailto:vantage@rmgfelm. com]
> > Sent: June 01, 2009 3:29 PM
> > To: vantage@yahoogroups .com
> > I am on progress (10.1b patch 330) also however I have some part update
> > methods that show up as out of date. I can not delete them or update them
> > without getting and error message about the ttlot can not be found, I do
> > not know if these are what is hanging up the part master.
> > Steve
> > From: Ken Cary [mailto:kencary@rocketmail. com]
> > Sent: June 01, 2009 3:05 PM
> > I'm on Progress (OpenEdge 10.1b). I've installed it on 2 different test
> > servers today and tried the part master search on both. I can search on
> both
> > servers. I have not tried searching anything else yet. Are you on SQL?
> > Ken
> > ____________ _________ _________ __
> > From: Steve_E <vantage@rmgfelm. com>
> > Sent: Monday, June 1, 2009 3:57:00 PM
> > I just restored my data base back to 407 and reinstalled the patch again
> > with the same results. I have a call in to support, but they did not have
> > 408 patch installed yet. Ken are you on progress or SQL?
> > Steve
> > From: Dan Godfrey [mailto:dgodfrey@ a-m- c.com]
> > Sent: June 01, 2009 2:53 PM
> > Have you throughly gone through all modules and clicked on all search
> > buttons yet? Are you planning on it?
> > Dan
> > From: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
> > [mailto:vantage@ yahoogroups <mailto:vantage% 40yahoogroups. com> .com] On
> > Behalf
> > Of Ken Cary
> > Sent: Monday, June 01, 2009 10:45 AM
> > To: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
> > Steve,
> > I installed 408 this morning and I have no problems opening the Part
> > Master and searching for parts.
> > Thanks
> > Ken
> > From: vantage03 <vantage@rmgfelm. <mailto:vantage% 40rmgfelm. com> com
> > <mailto:vantage% 40rmgfelm. com> >
> > Sent: Sunday, May 31, 2009 2:50:26 PM
> > Subject: [Vantage] 8,03.400 patch 408
> > I download the new 408 patch and installed it on my test server. I have
> > found that there is something wrong with the part bo. Can anyone conferm
> > that if you try to opend the part master you get an error message and
> > when the screen opens you can not search for any parts. I also found
> > that the methods that I have setup show up as out of date and when you
> > try to fix them you get a lot number eror message not allowing you to
> > update them.
> > Please let me know if this is not just an install problem on my server.
> > Thanks
> > Steve
