8.03.400 upgrade - Schema Change Icon
--- In vantage@yahoogroups.com, "Paul V. Blais" <pblais@...> wrote:
> If there isn't an icon run it through the start menu. Progams
à "manufacturing by epicor"
Here is a little more information. This is how the target was
configured by the installation:
D:\epicor\oe101b\bin\prowin32.exe -pf D:\epicor\CLIENT~2
\client\config\mfgtest.pf -ininame D:\epicor\CLIENT~2
\client\config\mfgsys.ini -rx -p applydfsql.w
I changed it to:
D:\epicor\oe101b\bin\prowin32.exe -pf D:\epicor\mfgsys803
\server\config\mfgtest.pf -ininame D:\epicor\mfgsys803
\server\config\mfgsys.ini -rx -p applydfsql.w
Hello. I've searched the message history and it seems that no one else
has had trouble finding this.
I'm running a test 8.03.400 conversion. I am at the point in the
instructions of Converting my Databases.
The instructions say to launch the Schema Change 8.03 Icon for the
appropriate database. I have searched everywhere and do not see a
schema change icon.
Can someone point me in the right direction?
If there isn't an icon run it through the start menu. Progams à "manufacturing by epicor"
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of lapulsifer
Sent: Wednesday, October 10, 2007 2:59 PM
Subject: [Vantage] 8.03.400 upgrade - Schema Change Icon
schema change icon.
I found that, but I get errors when I use those icons. It appears
that the target points to folders that do not exist. I managed to
change the target to the correct location of the files.
However, I get an error "** applydfsql.w was not found."
I searched for this and can't find a file with this name.
Thanks for pointing me in the right direction.
else
> schema change icon.
