9.05.702 - Simple Updatable BAQ on RcvDtl table - No Header record found - Processing aborting
All,
Simple Updatable BAQ on RcvDtl table just receipt date field is updatable.
Support said add all fields to the BAQ that the screen would typically use, I can follow the logic.
So I added every field but when updating get “No header records found – processing aborting.”
Any one seen this error and have a common workaround, fix or direction to point me too?
Patrick
