Apparently...
The 9.05.702A Patch doesn't always install correctly unless you right click and "Run as Administrator" for some unknown reason.
On Wed, Nov 19, 2014 at 9:48 AM, nedderweb@... [vantage] <vantage@yahoogroups.com> wrote:
Has anyone run into an issue with the 9.05.702A patch not properly updating the version of Epicor in the DB, thus creating a problem while trying to do an E10 upgrade with the migration process telling you that it can't migrate a DB that is not Epicor 9.05.702A or newer?
This is on SQL, non-unicode.
