We constantly create Pilot and test servers and using VM is the best way!
Short of a smart configuration change (apps server and ODBC) there is no other work and time to clone and change configuration is about 30 min
At the other side I have a server with same configuration (guarantied) and same performance â€" not sure why anyone would do otherwise if they had the technology
And if you don’t why don’t you get it as you will need it in the future
Motty
Motty
--- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@...> wrote:
> > and this includes making sure all drive letters
> >and file paths are the same
> Good point, I look for a PC with multiple disks.
> I like the install to be on anything but the "C" drive.
> --- In vantage@yahoogroups.com, "Ned" <TechnoBabbly@> wrote:
> > While I can mostly agree with this, one thing you want to make sure of when
> > you build a test server is to match your environment as much as possible,
> > and this includes making sure all drive letters and file paths are the same
> > on both machines, this will save you a TON of headaches when it comes to
> > moving the database from one machine to the other machine, then all custom
> > reports, and any file references aren't going to be messed up and need to be
> > fixed.
> > In reality though, I find that it's best to buy an inexpensive server to do
> > this on, although a VM would work great. Disk Speed and multiple processors
> > are huge, even if it's just to make the admins life easier doing the upgrade
> > conversions and schema changes.
> > -----Original Message-----
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> > Robert
> > Sent: Wednesday, August 03, 2011 10:30 AM
> > Subject: [Vantage] Re: 905 Test server
> > For our test server we are just using a Desktop PC. It doesn't run real
> > fast but it is still functional for a single user to get in and test fixes
> > or patches and a lot cheaper than using a server.
> > --- In vantage@yahoogroups.com, Nelson Dufour <ndufour@> wrote:
> > > Hi All,
> > > I am setting up a test server for 905 and would like to know what
> > > others have used.
> > > Thanks in advance for your replies,
> > > Nelson
> > > Nelson L. Dufour
> > > I.S. Services Mgr.
> > > 1691 Walker Rd.
> > > Windsor, ON. N8W 3P1
> > > 519-253-2461 313-965-8680
> > > Fax: 519-253-5911
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> > already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
