Security makes sense. The code I took it from writes to a hidden share with everyone having write permissions.
Sent: Sunday, August 14, 2016 2:33 PM
Subject: RE: [Vantage] ABL OUTPUT TO
Thanks,>> "D:\epicor\mfgsysdata\Reports\userxxx\PIF.txt".
>> "\\svr-dapp\EpicorData\Reports\" + DCD-UserID + "\test.txt".
Your example works as long as the "\\svr-dapp" part is my Vantage server name
(the previous D:\ drive example was a local path on the Vantage server)
But it is still failing when I try to point to other server names on the network.
I'm thinking it's a security issue here.
I checked with a test system on an isolated LAN & was able to send to other servers on that LAN.
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
