Accumulated Lead Time
9.05.700B2 on Production Server
9.05.700C on Test Server
Progress
-Rick Bird
IT Software Administrator
Rowmark, LLC.
9.05.700B2
--- In vantage@yahoogroups.com, "Steve_E" <vantage@...> wrote:
> Rick,
> What patch level are you on? Progress or Sql?
> Steve
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> that_guyy
> Sent: Tuesday, August 14, 2012 9:46 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Accumulated Lead Time
> Yes I have, but if you don't understand how it comes to the result it can be
> confusing. You will see that this is only valuable for longer lead times.
> For instance, the difference between manufacturing a Car Seat vs
> manufacturing a Car. The Car Seat probably has a cumulative time of <1 day,
> a car from start to finish probably has several days.
> Basically when it runs the calculation it is running a mini MRP and it seems
> to be following the same planning rules that would apply to MRP, such as Min
> Lot Size. This can be confusing if you don't realize that is what it is
> doing. For instance the Lead Time to Manufacture one Car Seat would be less
> than a day, so the MFG Lead Time would be 0. But to manufacture 5000 car
> seats could be 4 days, so the MFG Lead Time would come out to 4. In that
> example the Min lot size for the car seat was set to 5000.
> The other complaint I have heard is that the time is expressed in whole
> days, so anything less than a day gives 0, which depending on what you want
> to use the data for may not be valid.
> If this option doesn't seem like it will work for you, and you would put
> together a BAQ to do the calculation, you could use the manual values to
> store your results for easy access for Dashboards and reports so you
> wouldn't have to have a BAQ recalculate the values for each Dashboard
> Refresh or Report generation.
> Speaking of BAQ's, those have really come a long way from 8.03, so explore
> that and look at the Summary Table and Calculated Field options that are
> available now... I would imagine writing a BAQ for what you are after, could
> be fairly easy.
> -Rick Bird
> Rowmark, LLC.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Steve_E" <vantage@> wrote:
> > Sorry should have said Have you verified the data that MFG lead Time
> > Calculation produces?
> > Steve
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of
> > Steve_E
> > Sent: Tuesday, August 14, 2012 9:19 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: RE: [Vantage] Re: Accumulated Lead Time
> > Rick,
> > I am testing this on version 700C and one of the first thing I found is
> that
> > the information in the MRP Technical reference Guide list multiple filters
> > that can be applied but when you go to the process you only has Include
> > subassemblies.
> > How you verified the data the MFG lead Time Calculation produces ?
> > Thanks
> > Steve
> > Behalf Of
> > that_guyy
> > Sent: Tuesday, August 07, 2012 10:23 AM
> > Steve,
> > Moving to 9.05.700 from 8.03 has a lot of changes, pay attention to UOM's
> > and make sure you get them setup right the first time.
> > On page 103 of the 9.05.700 MRP Technical Reference Guide is a full
> > description of the MFG Lead Time Calculation and how it's used. Outside of
> > that, I find it to be a very handy piece of data to reference or bring
> into
> > a dashboard.
> > When you run the calculation you can pick which Part Class/Part/Plant for
> it
> > to calculate for. It's not something you would run all the time, just once
> > initially, and then after that whenever a Method would change or maybe
> once
> > a year.
> > Rick Bird
> > Rowmark, LLC.
> > > Sorry we are on version 8.03.408a. We just got test version of 9.05.700
> > > running over the weekend and I did find the mfg lead time calculation
> > > process. Just doing review to see if this impacts any other process when
> > > run.
> > > Thanks
> > > Steve
> > Behalf Of
> > > that_guyy
> > > Sent: Monday, August 06, 2012 4:18 PM
> > > Steve,
> > > What version of Epicor are you on?
> > > In either 9.04 or 9.05 this functionality was added to the application
> and
> > > stored in a field on the PartPlant table. It is done by running the Mfg
> > Lead
> > > Time Calculation, here is the Main Menu Path: Production
> > > Management>Engineering>General Operations>Mfg Lead Time Calculation
> > > You need the Engineering module.
> > > -Rick Bird
> > > Rowmark, LLC.
> > > > Has anyone put together a BAQ or Crystal report to give you an
> > accumulated
> > > > lead time for a BOM?
> > > > Steve
> > > > [Non-text portions of this message have been removed]
Has anyone put together a BAQ or Crystal report to give you an accumulated
Steve
Steve,
In either 9.04 or 9.05 this functionality was added to the application and stored in a field on the PartPlant table. It is done by running the Mfg Lead Time Calculation, here is the Main Menu Path: Production Management>Engineering>General Operations>Mfg Lead Time Calculation
-Rick Bird
Rowmark, LLC.
> Steve
run.
Steve
that_guyy
Steve,
-Rick Bird
Rowmark, LLC.
> Steve
Steve,
I did something with Excel so our Excel-addicted and Epicor-averse production and purchasing staffs (I didn't really say that out loud did I?) can see things in a more comfortable format. Basically it organizes all material demand (regardless of job) by due date minus lead time, then adjusts for inventory levels.
My next trick would be to adjust again for open POs... maybe someday when I have another minute.
Email me offline (ernie.lowell@...) and I can give you more information about how it works.
Ernie Lowell
Diba Industries
> Steve
Steve,
Moving to 9.05.700 from 8.03 has a lot of changes, pay attention to UOM's and make sure you get them setup right the first time.
On page 103 of the 9.05.700 MRP Technical Reference Guide is a full description of the MFG Lead Time Calculation and how it's used. Outside of that, I find it to be a very handy piece of data to reference or bring into a dashboard.
When you run the calculation you can pick which Part Class/Part/Plant for it to calculate for. It's not something you would run all the time, just once initially, and then after that whenever a Method would change or maybe once a year.
Rick Bird
Rowmark, LLC.
> run.
> Thanks
> Steve
> that_guyy
> Steve,
> -Rick Bird
> Rowmark, LLC.
> > Steve
Rick,
I am testing this on version 700C and one of the first thing I found is that
subassemblies.
Steve
that_guyy
Steve,
a dashboard.
a year.
Rick Bird
Rowmark, LLC.
> run.
> Thanks
> Steve
Behalf Of
> that_guyy
> Steve,
Lead
> -Rick Bird
> Rowmark, LLC.
accumulated
> > Steve
Steve
Steve_E
Rick,
subassemblies.
Steve
Behalf Of
that_guyy
Steve,
a dashboard.
a year.
Rick Bird
Rowmark, LLC.
> run.
> Thanks
> Steve
Behalf Of
> that_guyy
> Steve,
Lead
> -Rick Bird
> Rowmark, LLC.
accumulated
> > Steve
Yes I have, but if you don't understand how it comes to the result it can be confusing. You will see that this is only valuable for longer lead times. For instance, the difference between manufacturing a Car Seat vs manufacturing a Car. The Car Seat probably has a cumulative time of <1 day, a car from start to finish probably has several days.
Basically when it runs the calculation it is running a mini MRP and it seems to be following the same planning rules that would apply to MRP, such as Min Lot Size. This can be confusing if you don't realize that is what it is doing. For instance the Lead Time to Manufacture one Car Seat would be less than a day, so the MFG Lead Time would be 0. But to manufacture 5000 car seats could be 4 days, so the MFG Lead Time would come out to 4. In that example the Min lot size for the car seat was set to 5000.
The other complaint I have heard is that the time is expressed in whole days, so anything less than a day gives 0, which depending on what you want to use the data for may not be valid.
If this option doesn't seem like it will work for you, and you would put together a BAQ to do the calculation, you could use the manual values to store your results for easy access for Dashboards and reports so you wouldn't have to have a BAQ recalculate the values for each Dashboard Refresh or Report generation.
Speaking of BAQ's, those have really come a long way from 8.03, so explore that and look at the Summary Table and Calculated Field options that are available now... I would imagine writing a BAQ for what you are after, could be fairly easy.
-Rick Bird
Rowmark, LLC.
> Steve
> Steve_E
> Rick,
> subassemblies.
> Thanks
> Steve
> Behalf Of
> that_guyy
> Steve,
> a dashboard.
> a year.
> Rick Bird
> Rowmark, LLC.
> > run.
> > Thanks
> > Steve
> Behalf Of
> > that_guyy
> > Steve,
> Lead
> > -Rick Bird
> > Rowmark, LLC.
> accumulated
> > > Steve
I have submitted this to support because I have bills that have time on
level 3 of 12 hrs. The system is populating one day on everything from that
part up with the Manufacturing Lead Time Cumulative Time and This Level Time
have both the same values of 1 and the top level both at 14. From what I
can tell is that one should be this level and the other should be the total
and this is not happening.
Am I understanding the MRP reference guide to say there should be check
boxes so you can set to include Kit Time, Lead Time, Rough cut, Receive Time
and Transfer lead Time? If these boxes are missing from the process control
this would explain why my values are not correct.
Steve
that_guyy
be fairly easy.
-Rick Bird
Rowmark, LLC.
> Steve
Behalf Of
> Steve_E
> Rick,
that
> subassemblies.
> Thanks
> Steve
> Behalf Of
> that_guyy
> Steve,
into
> a dashboard.
it
once
> a year.
> Rick Bird
> Rowmark, LLC.
> > run.
> > Thanks
> > Steve
> Behalf Of
> > that_guyy
> > Steve,
and
> Lead
> > -Rick Bird
> > Rowmark, LLC.
> accumulated
> > > Steve
Rick,
Steve
that_guyy
be fairly easy.
-Rick Bird
Rowmark, LLC.
> Steve
Behalf Of
> Steve_E
> Rick,
that
> subassemblies.
> Thanks
> Steve
> Behalf Of
> that_guyy
> Steve,
into
> a dashboard.
it
once
> a year.
> Rick Bird
> Rowmark, LLC.
> > run.
> > Thanks
> > Steve
> Behalf Of
> > that_guyy
> > Steve,
and
> Lead
> > -Rick Bird
> > Rowmark, LLC.
> accumulated
> > > Steve
