in Kinetic the Accrued Vacation report is not displaying the SSN number, instead i am getting this
the expression in the text box is
=Fields!PREmpMas_SocSecNum.Value
How can I convert the garbage to the actual SSN number?
That looks like a hashed string. If that’s actual data, that’s someone’s SSN which can be decoded back to valid text. Maybe delete that image and make up some example text…?
The Numbers will be Encrypted just like the TIN’s, because if someone were to throw that report into the trash you dont want to have peoples Social Security Numbers floating out there. They arent needed to see Accrued Vacations
I would remove that column.
If you for some reason need them unencrypted, look here:
Otherwise, I’m with @hkeric.wci, drop them.
