Action Menu select by default
On Job Entry under Actions, Auto Schedule on Release is auto selected when you open job entry.
I know how to disable the menu item all together but I just want to change it to not be selected by default.
I un-selected one time (manually) and this remains un-selected for next instances.
Did you try saving layouts after unchecking auto schedule?
Saving layouts after unchecking worked. Thank you. Sometimes I look over the easy stuff and make it harder than it needs to be.
