Is it possible to create a BPM that sends an email with an attachment or hyperlink to a file?
If you are storing attachments on the shared drive then you can add the file full location as Hyperlink in the email. You will get a path from table ice.XFileRef and ice.XFileAttch.
I’ve just finished building this kind of BPM, here is the email and attachment part of the code
This grabs the PO that gets printed to a file location and it grabs any attachments that are attached to the PO Entry screen and sends it in an email from the BPM to the supplier
var mailer = this.GetMailer(async: false);
var message = new Ice.Mail.SmtpMail();
// message2.SetFrom(fromAddress);
message.SetFrom("Purchasing | Treadwell Group<do-not-reply@xyz.com.au>");
//message.SetTo(sendTo);
message.Priority = System.Net.Mail.MailPriority.High;
//message.SetCC(ordEntPer + "@xyz.com.au");
message.SetBcc("lrb@xyz.com.au; ");
// message.SetReplyTo(ordEntPer + "@xyz.com.au");
message.SetSubject(eSubject);
message.SetBody(eBody);
Dictionary<string, string> attachments = new Dictionary<string, string>();
if(sender.CheckBox05 == true)
var atts = Db.XFileRef.Where(f => f.Company == Session.CompanyID && Db.XFileAttch.Any(x => x.XFileRefNum == f.XFileRefNum && x.Key1 == poNum.ToString() && (x.RelatedToFile == "PODetail" || x.RelatedToFile == "POHeader"))).ToList();
if(atts != null)
foreach(var att in atts)
string filePaTha = att.XFileName;
var fileNamEa = filePaTha.ToString().Split('\\')[4];
attachments.Add(fileNamEa, filePaTha);
//attachments.Add(pdf, folder + pdf);
attachments.Add(fileName, filePath);
mailer.Send(message, attachments);
Hold off using the code I posted above, it only works if there is only 1 attachment found in the XFileAttch Db, if there is more than 1 found it throws and exception, I’ll edit this later with the exception details
All good, there were 2 files named the same causing it to fail
