Add Table to EDIPckSl Report Data Definition
Thanks for the update, Adam. I'm hoping to move to 407C over the next few weeks.
--- In vantage@yahoogroups.com, "adam.whipp" <adam.whipp@...> wrote:
> Nigel -- I just wanted to let you know that we are now on 407B, and this function now works. I linked in BOLHead and BOLDetail and they show up in the EDI flat file.
> --Adam
> --- In vantage@yahoogroups.com, "Nigel Kerley" <nigel.kerley@> wrote:
> > When using "outbound EDI" you *can't* add new tables to an RDD. That
> > is, you can create relationships but no data will be output for any
> > table that's not already included or linked.
> > So, if the table you need is not already listed as a Linked table for
> > some other table (and BOLDetail doesn't seem to be), then you're out
> > of luck.
> > We use BPMs to copy data from these missing tables into UD fields on
> > (for example) ShipHead or ShipDtl when the shipment is being created.
> > Nigel.
> > --- In vantage@yahoogroups.com, "adam.whipp" <adam.whipp@> wrote:
> > > We have duplicated the EDIPckSl RDD and called it 856. We need to
> > > include bill of lading info, so here is what we did: We have added
> > the
> > > BOLDetail table, and created the necessary relationship to join
> > > ShipHead to BOLDetail using the company, bolnum, and bolline
> > fields.
> > > When I print using "outbound EDI" report style, the XML file
> > contains
> > > the BOL Detail data like it should. However, the txt file
> > > that "outbound EDI" creates does not include any info from the
> > > BOLDetail table. Does anyone have any insight? I don't get how it
> > can
> > > be present in the XML but not in the txt file. Thanks for your
> > help!
> > > Adam
include bill of lading info, so here is what we did: We have added the
ShipHead to BOLDetail using the company, bolnum, and bolline fields.
When I print using "outbound EDI" report style, the XML file contains
BOLDetail table. Does anyone have any insight? I don't get how it can
be present in the XML but not in the txt file. Thanks for your help!
Adam
of luck.
Nigel.
the
fields.
contains
can
help!
> Adam
Adam,
I have a similar situation and a call logged with Epicor. I am trying
to use the ShipMisc table - which is shown in the RDD already, but not
outputting any schema or data - but does show in the XML. I have a
response, but it addresses if you get a 0KB XML - not the case for
either of us...But, since I am only in test at this time, I may try the
steps - I already have a busy day ahead, so it might take till the end
of the day before I get back to this.
Karen S
Of adam.whipp
Sent: Wednesday, January 28, 2009 6:21 PM
Subject: [Vantage] Add Table to EDIPckSl Report Data Definition
Adam
--Adam
> of luck.
> Nigel.
> the
> fields.
> contains
> can
> help!
> > Adam
When did 407B drop?
~Charlie
_____
adam.whipp
Sent: Wednesday, April 08, 2009 11:26 AM
Subject: [Vantage] Re: Add Table to EDIPckSl Report Data Definition
the EDI flat file.
--Adam
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Nigel
> of luck.
> Nigel.
> the
> fields.
> contains
> can
> help!
> > Adam
