Add table to Report Data Definition
Yes, it is possible sometimes, maybe.
With the Cut List, I was able to do this in the RDD:
CutList(standard table) --> JobHead(new table 1)
JobHead(new table 1) --> CustXPrt(new table 2)
JobHead(new table 1) --> Part(new table 3)
After finishing my Relationship in the Report Data Definition, then I repeat the same linking in Crystal. The Crystal Report correctly displays all the data I need from the proper tables for the Cut List.
However, I did not have the same positive results with the Job Traveler. On the Job Traveler, I am trying to do this:
JobPart(standard table) --> CustXPrt(new table 1)
CustXPrt(new table 1) --> Customer(new table 2)
But Vantage will not send any data from the Customer table to the Crystal Report. All of the Customer fields are blank in Crystal. I have been unable to figure out why this works with the Cut List RDD, but will not work with the Job Traveler RDD.
Vantage 8.03.404
Lynn
--- In vantage@yahoogroups.com, tomas paulavicius <tpaulavicius@...> wrote:
> I am on 8.03 version
> If you are in 8.03, then yes you can do this and yes you have to link the new table to one of the existing tables.
> Existing table should be one of standard report or can it be isn previous step added new table?
> When I link (Standart table)<->(New table 1) and (Standart table)<->(New table 2) I get all data, but it is incorrect.
> But when I link (Standart table)<->(New table 1)<->(New table 2) I do not get (New table 2 ) data, but I need to get It this way.
> Is it possible to link tables this way?
> Tom
Hello,
Maybe someone knows.
When adding new table to report data definition, is it required to add relationship between new table and standard table?
What if I what to add table like in "tree level"
Some standard table(1 level)
  |---New table(2 level)
     |---Another new table(3 level)
In this way I do not get data of "3 level" table.
I get data from only "2 level" table.
So It means that any new table should be linked with relationships only with standard report tables?
How can I add relation between two newly added tables?
Tom
I assume you're looking through a crystal report at the data definition?
Its been a while since I hacked up a data definition but I do remember
having to shore up some of the table linking in the database expert area
within crystal.
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site)
Of tpaulavicius@...
Sent: Tuesday, April 07, 2009 3:44 PM
Subject: [Vantage] Add table to Report Data Definition
Hello,
Tom
If you are in 8.0, you cannot add a new table even though it looks like
you can!
When you pick the report definition, click on new, then click on new
relationship.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of tpaulavicius@...
Hello,
Tom
I just looked back and noticed that there are a couple DD where I joined
two newly added tables together via a report relationship...
Rob Bucek
FAX: 715-284-4084
Of tpaulavicius@...
Hello,
Tom
Tom
I am doing all linking in Report Data Definition maintenance program.
Do you link newly added tables thorough RDD maintenance or Crystal report linking?
Tom
two newly added tables together via a report relationship. ..
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg com/>
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of tpaulavicius@ yahoo.co. uk
To: vantage@yahoogroups .com
Hello,
Tom
