Find out what method it's calling to get the data using a trace, then add a
post-processing routine to look up the terms code and set a UD field to that
value.
Kevin Simon
cooner_55421
Sent: Tuesday, August 30, 2011 12:59 PM
Subject: [Vantage] Add Terms Code and Description to form
Hi,
I am trying to add the customer.termscode and terms.description to the
customer credit manager form.
The existing customer view for the form doesn't have the termscode.
I started by adding a FKV (customer table to the NV: Customer).
This gives me the terms code but...
I can't add a SKV to the terms table to get the description.
I'm thinking that FKV and SKV are probably not the best choice, even if I
could get them to work.
I looked for an adapter to use instead, but so far, no luck.
Is anybody able to share a solution or ideas?
value.
Kevin Simon
cooner_55421
Hi,
