I am wanting to add in the text from the Memo that is attached to the Releases in the Order Entry menu under Lines however i am not sure how to connect the Memo to anything on the Purchase Order in the BAQ Phrase Build, wondering if you can help please?
While memo fields can be accessed in various ways, you might be better off adding a UD column to OrderDtls to hold your “memo”. Personally, I’d add a sheets to the Comments tab for “PO Comments”
