Our current setup for creating serial numbers for a electrical board is as follows:
- A job is created for the serialized part (C6174-S) -S stands for serialized.
- Underneath this part is our non-serialized part (C6175-NS) -NS stands for non-serialized. NOTE: C6175-NS is received as a quantity into inventory as a non-serialized part.
- The user clocks into the job for the C6174-S, where they add serial numbers one-by-one based upon the board they pull out. This is the serial mask we currently use:
Our supplier includes a sheet of paper inside each box that has a range of 50 serial numbers. I have tried using a serial mask like this one below…
When the user tries to add a range, there isn’t a text box to input the starting serial number. The default starts at C61740001.
Is there a way the user can add a range of 50 serial numbers on MES End Labor Activity using a serial mask?
