Exactly.
Inner joins need a match between the tables to end up in your result set.
Here's a pretty good visualization:
http://www.codeproject.com/Articles/33052/Visual-Representation-of-SQL-Joins
pluedke1107
Sent: Wednesday, June 13, 2012 3:08 PM
Subject: [Vantage] Re: Adding a table to Crystal
Thank you Vic- that works well. So if you do a left join from table1 to
table2, that means the table2 record does not have to exist, correct?
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Vic
Drecchio" <vic.drecchio@...> wrote:
Behalf Of
Checked by AVG - www.avg.com
Version: 2012.0.2180 / Virus Database: 2433/5065 - Release Date: 06/12/12
No virus found in this message.
pluedke1107
>PartRev
> If I understand you correctly, you want to look into a LEFT JOIN on
> from PODetail.[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf Of
> pluedke1107Part
> Sent: Wednesday, June 13, 2012 2:12 PM
> Subject: [Vantage] Adding a table to Crystal
> When adding an additional table to a Crystal report, what happens if there
> is no match in the table you are linking to? I want to add the drawing
> number from the Part Rev file to a PO line - there may not always be a
> Rev record. Do I have to do something special to test for this?No virus found in this message.
