Hi,
We’ll start simple here…
Have you checked the demand links? When the production quantity is zero, the software shows all checkmarks. The demand links is where you change the production quantities and determine why you are making it (stock, job, order).
If there is demand links - was the job un-engineered when you tried to make changes?
Belinda Hannah, CPIM
Dayton, OHIO
Sent: Tuesday, May 5, 2015 5:49 PM
Subject: [Vantage] Adding an assembly to a job
Hello,
When a job is created it doesn't appear to have the ability to add an additional assembly OR change the job quantities. This is something we easily did in the past, it just seems to have changed since we switched Epicor versions. We are currently on Version 10.0.700.4. Inside Job Entry - From the actions menu, I see Job Details > Assembly > Add Assembly. I click this option but nothing seems to happen. If I were to click "Add" sub assembly, operation, material, etc. - it takes me to the appropriate tab to make the addition. Is there a step that I might be missing with this newer version?? Also once a job has been scheduled and released it immediately shows that materials have been issued to the job even though it is supposed to be buy to order automatically.
Any help will be very appreciated!
Thank you!
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2015.0.5941 / Virus Database: 4342/9709 - Release Date: 05/06/15
