Adding Date & time into CSV File Name
Hi,
I have the following code in an Epicor Function which is currently exporting a csv file called Orders.csv.
What i need to happen is name the export Orders_320270918051.csv
I have tried the below but i am recieving errors when running the function as a schedule.
Errors i receive below.Any help here would be appreciated.
.ToString("MMddyyyyHHmmss")
That format makes it look like I’m typing while having a stroke, lol.
If it yells, you may have to do
Convert.ToDateTime(BpmFunc.Now()).ToString("MMddyyyyHHmmss")
    if (File.Exists(fullFilePath))
        // Generate a unique file name using a GUID
        string uniqueFileName = Guid.NewGuid().ToString() + "_" + this.callContextClient.CurrentUserId + "_" + FileName;
        string newFilePath = Path.Combine(filePath, uniqueFileName);
        // Rename the new file
        File.Move(fullFilePath, newFilePath);
        fullFilePath = newFilePath;
I added a Guid on the end :wink:
