You could also not use a retriever combo but rather call get List from the
adapter and bind it to the combo box. Then do that same with the other
combox but pass it the where clause.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Mon, May 23, 2011 at 11:12 AM, Jose Gomez <jose@...> wrote:
> You cna probably do that by using the Search Adapter Wizard. Give that a
> look under tools.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> <http://www.josecgomez.com/professional-resume/> <http://www.josecgomez.com/feed/>
> On Mon, May 23, 2011 at 11:07 AM, Kevin Simon <ksimon@...> wrote:
>> Giving this a little bump. any ideas?
>> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
>> Of
>> ksimon8fw
>> Sent: Thursday, May 19, 2011 9:22 PM
>> To: vantage@yahoogroups.com
>> Subject: [Vantage] Adding Job Assembly/Opr to UD form
>> I have a UD table form that I'm using, and I'm entering job numbers,
>> assembly sequence, and operations.
>> I can add a retriever combo for the assembly and operation, but how do I
>> go
>> about limiting the assuembly to only those for the Job Number that I
>> entered, and then after I enter Job and Assembly, I will want to limit the
>> Operation to only those for the Job/Assembly.
>> Thanks.
>> Kevin Simon
>> [Non-text portions of this message have been removed]
