That was too easy, thanks.
--SF
--SF
--- In vantage@yahoogroups.com, "Chris Crosta" <chris@...> wrote:
> If this is a crystal report you need to create a formula that you
can
> place your parameter field into and use the minimum and maximum
> function.
> Here is an example I use for my time collection.
> "Pay Period"& " "&minimum({?Pay Period Range})&" To "&maximum({?Pay
> Period Range})
> Chris
> -----Original Message-----
Behalf
> Of sanfranc415
> Sent: Friday, April 27, 2007 11:19 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Adding "My Parameter" to report.
> I've created a report that requires the user select a date range
before
> the report is generated. I'd like to display this range on the
> report. I've added the "My Parameter" which is the value required,
but
> it doesn't display on the report.
> Thanks,
> --SF
