Adding Records to EpiCombo Box
Hi,
I have an EpiCombo drop down in part entry that shows values from the UD01 table. We added a new option for the drop down in the UD01 table. The new record doesn’t show as an option in the drop down in part entry. This is our first time adding a new option since we went to E10. It used to work in 9 so I’m not sure if I’m missing a step to see the new record.
Melissa
What do your settings for the DropDown look like, what is the difference (if any) between the old and the new records in UD01?
Have you considered using UD Codes instead (they are meant for this)
It depends on where it gets the data from. The simplest way (not necessarily best long run) to add fields is to to type them in the customizations. Is that how this one was done? You will see a spot to put in a list on the customization.
