Thanks for your help Mark, the instructions you gave me worked
perfectly.
Thanks again, Jase.
perfectly.
Thanks again, Jase.
--- In vantage@yahoogroups.com, "Mark Wonsil" <mark_wonsil@...> wrote:
> Hi Jase,
> > Hi, We have just implemented Vantage 8.00.809d and i was
wondering if
> > anyone could tell me how to add the NetWeight field to the AR
form.
> > From here i am going to create a formula to show the total weight
of
> > the invoiced shipment.
> > I have added extra fields to other reports, but because this
field is
> > not attached to any of the tables in the ARform data definition, i
> > presume that i will have to add a new table. This is the part i
am not
> > sure of. Any help would be greatly appreciated.
> (This works on 8.03 and I think it would work on 8.00 as well...)
You do not
> have to add another table per se.
> Go to System Management | Company Maintenance and open Report Data
Definition.
> Choose the ARFORM Report Definition. Go to the Actions Menu and
Duplicate the
> definition calling it ARFORMPP or something like that.
> Expand the Report Tables Tree and click on InvcDtl.
> Click on the Report Table Tab. In the next row of tabs, choose the
Link Tables
> Tab and on the third row of tabs, choose Description Fields.
> In the drop-down box, choose PartNum. In the left pane, Fields
Available,
> select NetWeight and click the arrow to move it to the right pane,
Fields
> Picked. Click Save.
> Now the data definition is updated. You now have to tell your
Crystal Reports
> to use your custom Report Data Definition.
> Open up Report Style in the Company Maintenance Folder. Select
ARFORM. Here, I
> choose to do a New Report Style. Call it Precision Parts or
something clever
> like that. In the Data Definition drop down, use your new data
definition
> created above. Keep Crystal Reports for your report type and enter
the name of
> your custom Crystal Report in the Report Location. (You are using a
copy with
> a different name, right?)
> OK, go and print (or just generate) an invoice choosing this new
report style.
> If all goes well, this will put an XML file in your
MFGSYSDATA/REPORTS folder
> under your user name called something like AR Invoice
Form01234.XML. Copy this
> file to your development area.
> Open up Crystal Reports and load your custom Invoice Form. On the
menu, choose
> Database | Set Database Location. Replace your data source
(ADO.Net) by
> browsing to your newly created XML file and click Update. Do
a "Verify
> Database" here to make sure Crystal is aware of the new fields.
> If you expand the InvcDtl table in your Field Explorer, you will
now see a
> field called PartNum_NetWeight. (Apparently, all of
the "description fields"
> have the naming convention of {lookupfield}_{fieldname}) Now you
have the
> field that you want. Whew!
> While that was a lot of steps, you were probably doing most of them
already.
> Just an aside for lurkers, if one only wants to change a label on a
Crystal
> Report, you can change the report labels in the Report Data
Definitions
> without ever modifying the Crystal Reports. Just go to the Report
Labels tab
> and change the text.
> Finally, if this report style is working the way you want it, set
it as the
> Default Report style and it will be the first one that appears in
the Print
> Dialog Box.
> HTH,
> Mark W.
