Advanced Unit of measure in Job Report Quantity
When creating a job for an Attribute tracked part (in this case, Length) you need to specify the Attribute set. I pick 3 ft. This is from an Attribute Set combo box of differing lengths I can pick from.
The scenario is that while the job is for producing timber pieces at 3ft length, it also can produce shorter lengths as there can be a defect in the length, and it is cut down to the next nearest allowable length (2 ft).
In Report Quantity you can change the Set Attribute from 3 to 2ft, and it does convert to the number of pieces and allow you to Save. You can see the transaction in the Job Tracker.
However! When you do the Job receipt to Inventory, while you can change the Attribute to 2 ft, when you hit Save you get an error message saying you cannot receive a Planning Attribute set that is different to the one set in the job.
Has anyone tried to do anything like this in Kinetic? We are on 2024.2.
