Thanks..that is what I thought it was going to be.
Kersten MacLennan
IT/ERP Analyst
Semrock
A Unit of IDEX Corporation
3625 Buffalo Road, Suite 6
Rochester, New York 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
The Standard in Optical Filters for Biotech & Analytical Instrumentation
Hundreds of Thousands of Ion Beam Sputtered filters delivered -
extensive inventory now!
The information contained in this message and any attachments may be
privileged, confidential, and protected from disclosure. If the reader
of this message is not the intended recipient, or any agent responsible
for delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution, or copying of this
communication may be unlawful and therefore strictly prohibited. If you
received this message in error, please reply to the message and delete
it. Thank you
Of Nigel Kerley
Sent: Wednesday, November 19, 2008 10:11 AM
Subject: [Vantage] Re: Aged Receivables Report
Hi Kersten,
I don't believe you can add more buckets inside Vantage. You can't
add Calculated Fields to the report definition without the SDK.
So the only way I can think of would be to amend the Crystal Report
and put some new formulas in there.
If you added in the field "ARDtls.CurDueDate" into the standard
report definition, then maybe a formula like "ARDtls.CurDueDate >
RptParameter.AgingDate + ###" would work. The ### being your new
bucket.
HTH.
Nigel.
"kam4085" <kmaclennan@...> wrote:
Kersten MacLennan
IT/ERP Analyst
Semrock
585-594-7009
585-594-7095 fax
kmaclennan@...
it. Thank you
Of Nigel Kerley
Hi Kersten,
bucket.
HTH.
Nigel.
>buckets.
> I need to modify our receivables report. The standard has a current
> bucket and then 5 past due buckets. I need to have 9 past due
> The entire report is populated through calculated fields. Is therea
> way I can get to these so I can modify and add more? The currentreport
> takes whatever is left beyond the next to last bucket andcalculates
> the balance due for the last bucket. I need to split this value upand
> then add calculations for the new paramters. I know I can add[Non-text portions of this message have been removed]
> calculated fields in the report definition but I don't know how to
> define the calculations.
> Any help would be appreciated.
> Kersten
