I came across this and thought someone might get some time to evaluate it.
I started playing around with it, and found that it can’t keep its goal straight. It can go off the rails and hallucinate garbage pretty quickly. I still use BING AI and ChatGPT for coding. I think the blackbox one could be good if you give it very specific requests. I also seems to ignore my request to keep data formatted in a particular syntax, instead preferring to insert a different language to complete the code.
Good info @NateS - thanks for giving it a trial run!
