Sorry everyone, that logic is wrong and will always fire (not more
than 0). I'll update when I get a solid solution.
Everyone have a good weekend, nothing to see here - please drive
through.
through.
--- In vantage@yahoogroups.com, "Patrick Parker" <pbparker@...> wrote:
> Yeesh, once again I find the solution soon after I've asked for
help.
> In any case, for those that may want this feature, I'm using this
> method. This will create a pop-up alert when they attempt to post
the
> invoice.
> Add a Post-Process BPM on the InvcGrp.PrePostInvoices method.
> I added the condition of:
> number of rows in the query is not more than 0
> My query is:
> for each InvcHead where InvcHead.InvoiceHeld = 'true' AND
> InvcHead.GroupID = '%ttInvcGrp%'
> For my action, I simply raised an exception and put some wording in
> there that indicated that the user needs to resolve the hold status
and
> re-post.
> --- In vantage@yahoogroups.com, "Patrick Parker" <pbparker@> wrote:
> > When you have an order that's marked Time/Materials, it's by
default
> > held at the point of invoicing so that when you pull it into the
> > invoice group, you're supposed to update the costs.
> > However, if you happen to miss the Hold Invoice checkmark and
simply
> > post the group, everything clears in AR Invoice Entry as it
normally
> > would and you'd assume it was posted when in fact it wasn't.
> > I'm trying to create a BPM to prompt the user that there is an
> shipment
> > invoice entry that's marked Hold, has anyone done this yet? I
either
> > haven't got the right query or I'm on the wrong directive -
either
> way
> > I'm looking for some help if anyone has done this.
