Allow API V1 (checkbox in User Account Security Maintenance)
I was researching whether to disable API V1 following the tip from How to disable Epicor Rest API v1?.
But I see in “What’s new in 2024.1” that there is a new standard feature:
User Account Security Maintenance now has the Allow API V1 check box. This permission indicates whether the user can run the original Kinetic version 1 application program interfaces (APIs). Existing users automatically have this permission. However by default, new users do not have this permission.
Since this is now the default setting, I guess that removing this permission would probably work for users in an installation that has never been on a version prior to Kinetic (like mine). Are there any common features or integrations that would be incompatible with this setting?
Just found out the Epicor Data Discovery does not work if you disable APIv1.
I mean EDD, hardly ever works anyway, but this prevents access for any user without APIv1 enabled.
Episode 2 Whatever GIF
Does the browser work without v1? :thinking:
Technically no, but also yes.
Epicor has super secret powers.
Edd doesn’t install if you have named pipes turned off either.
EDD also doesn’t install if you don’t install it.
Think About It GIF by Identity
So far, turning off API V1 hasn’t caused us problems (Kinetic in the browser works fine), however we are still in the implementation phase and probably have not finished testing everything yet.
In June EpicCare did confirm for me that the online documentation is incorrect: they had originally planned to begin disabling V1 by default for newly created users in 2024.1 (as the documentation says), but decided to delay that change until 2024.2.
Would you mind elaborating on this some? Not the super secret power part since I don’t want Epicor to get mad, but why would the browser not work?
No, it works regardless is what I meant.
I said no, because almost all of the web UI for Kinetic uses API v1, so if it was really disabled, it shouldn’t, but there is some Tom Foolery for the application itself that still allows it to work.
Makes sense. Thanks!
