It would be nice to disable the popup every time a BAQ is saved or tested, in the designer, that contains fields that have security restrictions. I’d rather see in the Display Fields tab either a different color or a another column that indicates that the field has potential restrictions. I don’t need to see it every time it’s modify saved and/or tested.
