Allowing MES/Shop floor production employees to see CAD drawings
That's good to know. Thanks for the information, I'll have to check that out!
Virginia
--- In vantage@yahoogroups.com, "Brian Roberts" <broberts@...> wrote:
> One correction: attachments can be linked to a part revision (while its
> un-approved), as well as to a part. When you create a job and choose a
> revision, the attachments from that revision are linked to the job... so
> printing from job tracker will always give you the correct revision.
> Brian.
> Of Virginia Joseph
> Sent: Friday, June 17, 2011 1:04 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Allowing MES/Shop floor production employees to
> see CAD drawings
> Hi Jim, You can use Vantage's Document Management Module. You create an
> attachment to the Part (Epicor calls it an attachment but it is really a
> shortcut to the document on your server)which can be any document you
> want to associate with the part: drawings, tech sheets, customer
> specifications, etc. In MES, the machinists can launch part tracker and
> view and print all attachments that exist for the part. Then you would
> just need to make sure the workstation running MES have the correct
> software for viewing all the different file types.
> You would also need to put a process in place to ensure that the
> machinists pick the right attachments for the revision on which they are
> working becuase the attachements do not link to a specific part
> revision, they link to the part.
> Virginia Joseph
> Deep Hole Specialists, LLC
> vjoseph@... <mailto:vjoseph%40deephole.com>
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Jim
> Chance <jim_chance@> wrote:
> > Well, that's a possibility.
> > My goal is to make it easy for the shop floor operator to see the
> drawing for the job/release/part/rev that they are working on for the
> process.
> > First thought was do to this in MES since that is where they login to
> the job/part/operation. Then give them the ability to click on something
> to see the CAD PDF link.
> > Based on this, does your approach sound similar?
> > Jim Chance, PMP - IT consultant/contractor
> > DBA Practical Technology Solutions
> > 1485 County Road 1575
> > Ashland, Ohio, 44805
> > Office/Home: 419-557-2225
> > Cell: 419-651-6704
> > Fax: 732-601-6704
> > Email: jim_chance@
I would like to enable the capability of allowing a shop floor employee to view the CAD drawing on the part for the job/operation that is being worked on.
Has anyone done this?
Did it require modifying the MES menu w/ a new application/solution?
Are you attaching the CAD drawing to the part as a link?
Any details and eleborations would be greatly appreciated.
I wrote a web app that allows user to enter Job# and the select operation from ddl and it displays info from vantage. I also included a search box that will query our sharepoint document library and they can pull up the drawing from there.
Probably not exactly what you are looking for, but it beats having vantage/mes running on dozens of workstations
bw
My goal is to make it easy for the shop floor operator to see the drawing for the job/release/part/rev that they are working on for the process.
First thought was do to this in MES since that is where they login to the job/part/operation. Then give them the ability to click on something to see the CAD PDF link.
Cell: 419-651-6704
Fax: 732-601-6704
Email: jim_chance@...
PMP Certified, IT purveyor since 1985. SQL Server, Crystal, Project Management, HP3000, UNIX, Migrations/Conversions, ERP expert.
Primary strengths:
1) IT in manufacturing 2) Analyst 3) ERP 4) MS SQL 5) Crystal reports
Robust SDLC experience. Completed the development & implementation of over 1200 application solutions to-date. PMP, Project Management Professional credential by PMI. Strong development, analysis and integration skills. Sarbanes Oxley knowledge. Single handedly converted legacy systems to MS SQL multiple times. Broad understanding of capital projects. Experienced hands-on analyst who has also managed budgets, work plans, schedules, deliverables and responsibility matrices. Additionally, set objectives, build, track and monitor project plans using MS Project with PMBOK methodologies. Used integration, technical and negotiation skills to achieve successful project outcomes around issues, scope, schedule, costs and resources.
Information Technology Acumens:
Business Systems: Tier I & II ERP systems: Mapics, Jobscope, JEE, Macola, Epicor/Vantage and many complex custom systems.
Professional: Project management, Kanban, Kaizen lean manufacturing, IT management, SOX, supervision, vendor negotiations, department/capital budgets, disaster planning/prevention, fail-over/high availability/up-time solutions.
Operating Systems: HP3000, IBM iSeries AS400, IBM & SCO & HP UNIX, Linux, Windows since 1985, Windows 2000 & 2003 server enterprise editions.
Databases: DB2, MS SQL 2000/2005/2008, HP3000 TurboImage XL, Access, Oracle., Macola, Epicor, Vantage, Jobscope.
Programming languages: MS SQL, T-SQL, PL-SQL, scripting, triggers, stored procedures, DTS, SSIS , Crystal 8.5 9 XI & 2008, Qedit, Suprtool, Powerhouse, Cognos, Quiz, QTP, Quick, Quad, HP & IBM query COBOL CICS & COBOL HP3000, ASKplus, DataMax
Software: MS Studio 2008, MS (Access, PowerPoint, Excel, Word, Exchange, ), Lotus Notes, AD, Query Analyzer, Enterprise Manager, terminal server, VPN, TOAD, MS Exchanger server admin., ODBC, PDA, RF, Bar-coding, MS Visual Studio 2008, InfinityQS, Red Prairie
Rent our condo in sunny warm Estero, Florida:
http://www.vacationrentals.com/vacation-rentals/23683.html
>Sent: Wednesday, June 15, 2011 3:05 PM
>Subject: [Vantage] Re: Allowing MES/Shop floor production employees to see CAD drawings
> Â
>bw
As long as you had a working link stored in a comment or UD field, I don't see why it wouldn't work.
We use a handful of MES stations to act as time clocks and for other lookups / prints.
The primary workstations look up Operation data and drawings through browser windows - another web app allows start and end activity transactions to be recorded without MES session running.
For quick little transactions, lookups, webservices work just dandy.
bw
> Cell: 419-651-6704
> Fax: 732-601-6704
>> From: bw2868bond <bwalker@...>
> > ÂÂ
> >bw
We are part of the way there, but the final steps in our process are
manual & paper. We attach the drawings as PDF files to the part
revision when parts are created, and these get automatically attached to
the job when it is created. There is a simple naming convention for
multiple attachments ("assembly", "packaging", etc). These attachments
are viewable/printable via job entry (often printed the same time as the
traveler) and via job tracker (which is accessible from the standard
MES). But its several clicks to view/print, and we've never tried to
make it automatic - if you do that, I'd be interested in your solution.
Brian.
Of jim_chance
Sent: Wednesday, June 15, 2011 2:19 PM
Subject: [Vantage] Allowing MES/Shop floor production employees to see
CAD drawings
worked on.
Jim,
You should be able to just add a button to a form, and call the appropriate program (pdf viewer, cad viewer, etc.). You’ll have to add some logic before it to read the job information to get the link where these are stored, but all of this is fairly standard customization. I’ve created customizations that open up a PDF for users at the click of a button within the Start Production Activity.
Contact me offline if you need a nudge in the right direction.
Kevin Simon
SimsTrak Consulting
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jim Chance
Sent: Wednesday, June 15, 2011 3:22 PM
Subject: Re: [Vantage] Re: Allowing MES/Shop floor production employees to see CAD drawings
Cell: 419-651-6704
Fax: 732-601-6704
Email: jim_chance@... <mailto:jim_chance%40yahoo.com>
Primary strengths:
From: bw2868bond <bwalker@... <mailto:bwalker%40adcocircuits.com> >
>To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
>bw
>--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "jim_chance" <jim_chance@...> wrote:
Hi Jim, You can use Vantage's Document Management Module. You create an attachment to the Part (Epicor calls it an attachment but it is really a shortcut to the document on your server)which can be any document you want to associate with the part: drawings, tech sheets, customer specifications, etc. In MES, the machinists can launch part tracker and view and print all attachments that exist for the part. Then you would just need to make sure the workstation running MES have the correct software for viewing all the different file types.
You would also need to put a process in place to ensure that the machinists pick the right attachments for the revision on which they are working becuase the attachements do not link to a specific part revision, they link to the part.
Virginia Joseph
vjoseph@...
> Cell: 419-651-6704
> Fax: 732-601-6704
Brian.
Of Virginia Joseph
see CAD drawings
Virginia Joseph
process.
> Cell: 419-651-6704
> Fax: 732-601-6704
