We create a job order with sub-contractor operation. Then, the purchaser goes to the New PO Suggestion to generate the PO.
May I know can we change to a new Partnum?
May I know is there any impart if the change the Part?
You can’t change the Part in PO Suggestions (as far as I know), but you can create the PO for a different Part and tie it to the Subcontract Operation.
