Is there a module that shows what material is in what bin? Transferring inventory to a job which has a resource with a bin assigned to it…how can I see all of the items in that bin?
There is no out-of-the-box report that allows you to pick a bin and see what is in it… but it is an easy BAQ (Business Activity Query) to write using the PartBin table.
There is a Data Collection menu item called BIN Tracker:
If it’s under the HandHeld menu tree, it’s designed for the Honeywell Windows Mobile devices… and Epicor has deprecated that line.
There IS a zCRM-PartBins system query already defined that you could copy and use.
