AMM - Material Queue
I’ve been testing this most of the day. Does AMM’s material queue support moving subassemblies? I cannot get a subassembly to populate in the material queue.
Say we have subassembly X with an operation sequence of 10-Cut, 20-Weld. The output bin for CUT is Floor, and the input bin for Weld is FAB Staging. When op 10 is complete, shouldn’t Epicor generate a material move request for that subassembly, or does it not work with subs?
Do you have auto-move turned on?
Auto move is off.
Yes. Movement is tied to operations, which only can be applied to subassemblies. You’ve probably got something not set right in your resource group / resource.
You are correct. I didn’t realize that the resource group in and out warehouses don’t cascade down to the resource level. I just assumed that they would. I hope that is my fix.
