I wondered if that is what was happening, but I was not there to see
if the receiver clicked on the to location button.
Thank you
--- In vantage@yahoogroups.com, "lapulsifer" <sharon.pulsifer@...>
Thank you
wrote:
>directly
> We are using the material queue on the barcode handheld. What we
> have found is if you set the location when you receive, then a
> material queue transactions is not generated. If you take the
> default values, then a material queue entry is created.
> This was good for us, because part of our warehouse receives
> to the final location. We did not want a material queue entry inparts
> that case.
> --- In vantage@yahoogroups.com, "c.chest" <c.chest@> wrote:
> > Oh...sorry, I should have been more specific. When receiving
> > from a Purchase Order, one is going to the material queue and onewith
> is
> > going right to inventory. Any idea why this may be happening.
> > --- In vantage@yahoogroups.com, "saab_barracuda" <chris.clunn@>
> > wrote:
> > > Maybe check the Resource Group setup associated with the last
> > > operation for each part. There is an "Auto Move" check box
> theoverlooking
> > > location. Here's the note from the Resource Group help file:
> > > Auto Move
> > > Select this check box to indicate that you want to create a
> material
> > > queue record when completing work in this resource group.
> > > > Looking for some help...I have two part numbers, neither are
> lot
> > > > controlled. When I receive one of them in MES receiving, the
> > > > part/quantity goes to the material queue to be moved to
> > inventory...the
> > > > other one goes right to inventory. Going through the exact
> same
> > > > process with both. Why does one end up in the material queue
> and
> > one
> > > > does not? Has anyone else experienced this? Am I
> > > > something?
> > > > Cindy
