Server Side Error
Server Side Exception
EpicorServerException
Correlation ID: 19a734a1-e3f6-4e3c-bdfa-0af6bb79234f
Description: Unable to connect to the remote server
Inner Exception: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full 192.168.1.38:80
Program: System.dll
Method: GetRequestStream
Original Exception Type: WebException
Framework Method: Invoke
Framework Line Number: 0
Framework Column Number: 0
Framework Source: Invoke at offset 154 in file:line:column :0:0
Server Trace Stack: at System.Net.HttpWebRequest.GetRequestStream(TransportContext& context)
at System.Net.HttpWebRequest.GetRequestStream()
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at Ice.Core.SsrsReportService.ReportExecutionService.LoadReport(String Report, String HistoryID) in C:_Releases\ICE\UD10.2.500.28FW\Source\Server\Internal\Lib\TaskLib\Web References\SsrsReportService\Reference.cs:line 287
at Ice.Services.BO.ReportSvc.GetSsrsReportPageSettings(String reportLocation, Double& height, Double& width, Double& top, Double& bottom, Double& left, Double& right) in C:_Releases\ICE\RL10.2.500.0FW\Source\Server\Services\BO\Report\Report.cs:line 830
at Ice.Services.BO.ReportSvcFacade.GetSsrsReportPageSettings(String reportLocation, Double& height, Double& width, Double& top, Double& bottom, Double& left, Double& right) in C:_Releases\ICE\RL10.2.500.0FW\Source\Server\Services\BO\Report\ReportSvcFacade.cs:line 427
at SyncInvokeGetSsrsReportPageSettings(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func2 func) in C:\_Releases\ICE\UD10.2.500.28FW\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59 at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func2 func) in C:_Releases\ICE\UD10.2.500.28FW\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28
Inner Trace:
: at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
