I am not aware of any BPM that is writing to the event log and I have just checked the appserver.config file. All switches are off. I can send you part of our event log if you wish?
Just thought I’d add to this,
I’m seeing
CheckInPartRev: and DeleteRevLock:
in our event logs I have a user punching in a heap of MoMs. Running @markdamen script didn’t yield anything even when I replaced and searched for the string mentioned above.
Not sure if this has anything to do with anything in Company Config, but I’d like to know.
If anyone knows it would be really, really helpful.
My script will only pick up code from BPMs, anything Epicor controlled one their source code you’re stuck with unless there is a config option for that logging
@knash unfortunately I never did get to the bottom of it. I’ve since moved on so if I was being funny I could say it resolved itself. I do agree has to be something code related (duh)… I’ll keep an eye out on my travels when I am doing any engineering WB work.
