Another ODBC 5.0 question-resolved
Hi all,
going thru the list, I found this message which applies to a situation I'm
having here too.
Setting the Isolation Level to READ UNCOMMITTED in a System DSN effectively
solved the problem.
The difference is that I want to use a File DSN, and it doesn't seem like I
can set the Isolation Level parameter directly from the ODBC manager.
So, is there anyway to edit the File DSN to manually set this parameter, or
do I absolutely have to use a System DSN ?
Best regards,
Luc Morin
Electrical Designer
Wulftec International
lucm@...
(819) 838-4232, ext. 232
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
Sent: Friday, November 09, 2001 9:16 AM
Subject: [Vantage] Re: Another ODBC 5.0 question-resolved
In regards to the error message I posted ysterday: Failure getting
record lock on a record from table [Vantage Table Name] (#-210015).
I submitted this question to Tech support also and got the answer
this moring which i tested and works. So, in case anyone else comes
accross this, the solution is:
Go to the Advanced tab of the ODBC DSN and change the Default
Isolation Level to:"Read Uncommitted" This will allow you to get
records even when the table is locked.
Ever since the upgrade to 5.0, when I run access queries and reports, I
occaisonally get the error:
Failure gettign record lock on a record from table [Vantage Table Name]
(#-210015).
When I check the locks, that table is indeed locked, but why does that
prevent an access report from running, I'm not trying to update data.
I never got this on 4.0. Does anybody know if there is some kind of setting
that lets me query records even if they are locked?
Boy, that's a new one Sarah. I've never seen that error in 5.0 at all.
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Thursday, November 08, 2001 3:01 PM
Subject: [Vantage] Another ODBC 5.0 question
(#-210015).
