AP Clearing
Thanks for the help.
--- In vantage@yahoogroups.com, Mark Wagner <mjfw2003@...> wrote:
> Run your WIP Reconciliation report and look at your transactions under your AP Clearing account. You can also run your received not invoiced report under AP/Reports
> From: Millicent <millicent.massey@...>
> To: vantage@yahoogroups.com
> Sent: Thursday, September 13, 2012 11:54 AM
> Subject: [Vantage] AP Clearing
> ÂÂ
> Can anyone help with the steps to reconcile the AP clearing account? I apologize if my request shows up twice.We are experiencing e-mail issues.
> Thanks.
Does anyone know of a quick way to reconcile the AP Clearing account? I
ran a crystal report for all open receivers that haven't been invoiced
and that does not tie into the ending balance of the AP Clearing
account.
Any suggestions would be appreciated.
Michelle de la Vega
Business Applications Manager
Cold Jet, LLC
513-831-3211 ext 400
513-831-1209 fax
www.ColdJet.com
Did you check the dates of the invoice... I run the report with exaggerated dates to make sure I get anything that might have errors on the date field. 1/1/00 to 12/31/50
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Michelle de la Vega
Sent: Thursday, June 16, 2005 10:20 AM
account.
Michelle de la Vega
Cold Jet, LLC
513-831-1209 fax
www.ColdJet.com
Yahoo! Groups Links
Michelle,
Gotcha's can include, but aren't limited to, material items that are
prepaid (payment is made, then parts are received), material that is
paid for with a credit card, material invoices not matched to receivers,
and timing issues like Stephanie mentioned. Many of our problems went
away when we set up a clean cut at month end. We do this by halting all
receiving after month end close, running the received not invoiced
report with a wide date range (per Stephanie), then running the GL, then
cutting loose receiving.
James
Of Geary, Stephanie
Sent: Thursday, June 16, 2005 9:39 AM
Subject: RE: [Vantage] AP Clearing
account.
Michelle de la Vega
Cold Jet, LLC
513-831-1209 fax
www.ColdJet.com
Timing seems to be key for a number of reports in Vantage.. I come in that last day of the month after everyone leaves to run reports, to make sure it is as clean as it can be.... I wish there was a way to "LOCK" people out of areas until month end is finished ...
Of James Martin Jr.
Sent: Thursday, June 16, 2005 11:05 AM
Michelle,
James
Of Geary, Stephanie
account.
Michelle de la Vega
Cold Jet, LLC
513-831-1209 fax
www.ColdJet.com
Yahoo! Groups Links
Would a stable / static copy of the data help? You can take a month-end
backup and restore it into a test database for reporting.
Also, NOT setting up all your GL periods a year in advance is highly
recommended. At a minimum, don't set up December - this rejects those
back-dated January transactions that end up 11 months forward. Even
leaving out the next month until you're done reporting and closing will
stop many transactions, since there's no GL Period associated with the
calendar date.
Can you use the "Budget" if the fiscal periods aren't defined?
Of wmc20@...
Sent: Thursday, June 16, 2005 12:14 PM
calendar date.
Yahoo! Groups Links
Thanks.
Â
Thanks.
