Since the 2024.2.3 update has ANYONE else had a problem with a kinetic configurator where UD method calls fail because it is now using V2 rest call rather than V1.
Epicor are so far as much use as a chocolate fire guard, we can’t test because of this…im literally at a loss.
Everything worked perfect before the upgrade.
If i know i am not the only one i can present this to our account manager at least and HOPEFULLY get somewhere.
In the debugger i get a 403 error on Execute user defined when i am making a UD method call to the database, it says that i need a valid API key for the rest call, but its a configurator not an external call…
Tried creating an API key and adding all the BO methods to it relating to the configurator…still nothing.
I was hoping this was a larger issue and i could add this thread to my case
