Sent: Monday, October 7, 2013 2:35 PM
Subject: RE: [Vantage] Re: APM Faxing
<div id="ygrps-yiv-1235612886yiv0602664917ygrp-text">
<div class="ygrps-yiv-1235612886yiv0602664917WordSection1"><div class="ygrps-yiv-1235612886yiv0602664917MsoNormal">Does anyone know if APM faxing requires hardware? Modem? Or is it solely electronic without the need for a modem? </div><div class="ygrps-yiv-1235612886yiv0602664917MsoNormal"> </div><div class="ygrps-yiv-1235612886yiv0602664917yqt9064740136" id="ygrps-yiv-1235612886yiv0602664917yqt37533"><div><div style="border-top:solid #B5C4DF 1.0pt;"><div class="ygrps-yiv-1235612886yiv0602664917MsoNormal"><b><span style="font-size:10.0pt;">From:</span></b><span style="font-size:10.0pt;"> vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] <b>On Behalf Of </b>jarradlayne<br clear="none"><b>Sent:</b> Monday, October 07, 2013 11:36 AM<br clear="none"><b>To:</b> vantage@yahoogroups.com<br clear="none"><b>Subject:</b> [Vantage] Re: APM Faxing</span></div></div></div><div class="ygrps-yiv-1235612886yiv0602664917MsoNormal"> </div><div class="ygrps-yiv-1235612886yiv0602664917MsoNormal"> </div><div id="ygrps-yiv-1235612886yiv0602664917ygrp-mlmsg"><div id="ygrps-yiv-1235612886yiv0602664917ygrp-msg"><div
id=“ygrps-yiv-1235612886yiv0602664917ygrp-text”>
— In vantage@yahoogroups.com, "jarradlayne" <jarradlayne@…> wrote:
> Hello Group,
> I have a question regarding APM faxing. I am currently trying to set up APM to fax a document. I have successfully set up APM to email the document, which I was doing as s test to make sure I covered everything needed. Apparently for the fax I am missing a step.
> Is there a set up step where I need to point to a certain fax number / machine? This is not using a third party eFax type set up these are physical fax
machines. Does that matter? I'm sure this means some type of difference in the set up.
> I've created a routing list with distribution to 'All Recipients in this group' with a value related to a fax number in the 'Members' portion. Checkbox is checked inside the Members list.
> I've set up the "Recipients" portion, on the general tab I have added a fax 'Method', its the same 'Property Value' as in the routing list. on the 'Member Of' tab shows the Routing list I've created.
> In Documents Type 'Properties Tab' I have the Property Value of the Fax contact i've added to the routing and recipients. ERM Config tab inside the Configure controls this launches the ERM Options window. Inside of this window on the ERM Options Tab I have the 'Identify Document' set to a unique key for this report. Input type EMF, 'File
Action' Process normally. Now the ERM Properties tab, here I list the Property Value and set the location on the report that the fax number is being pulled from as well as a formula to format the number. Heres the formula as this may be the issue:
> if len(PropertyValue)>1 Then
> PropertyValue = Replace(PropertyValue,"-","")
> PropertyValue = Replace(PropertyValue,"(","")
> PropertyValue = Replace(PropertyValue,")","")
> PropertyValue = Replace(PropertyValue,".","")
> PropertyValue = Replace(PropertyValue," ","")
> End if
> if len(PropertyValue) < 10 Then
> TextOut = "7" & PropertyValue
> else
> TextOut = "71" & PropertyValue
> End if
> Other than that I really haven't changed or set up anything else. If anyone sees something or has any insight into this it would greatly appreciated.
> Thanks
</div>
<div class="ygrps-yiv-1235612886yiv0602664917yqt9064740136" id="ygrps-yiv-1235612886yiv0602664917yqt40404"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-mkp #ygrps-yiv-1235612886yiv0602664917hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-mkp #ygrps-yiv-1235612886yiv0602664917ads {
margin-bottom:10px;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-mkp .ygrps-yiv-1235612886yiv0602664917ad {
padding:0 0;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-mkp .ygrps-yiv-1235612886yiv0602664917ad p {
margin:0;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-mkp .ygrps-yiv-1235612886yiv0602664917ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-sponsor #ygrps-yiv-1235612886yiv0602664917ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-sponsor #ygrps-yiv-1235612886yiv0602664917ygrp-lc #ygrps-yiv-1235612886yiv0602664917hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-sponsor #ygrps-yiv-1235612886yiv0602664917ygrp-lc .ygrps-yiv-1235612886yiv0602664917ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917activity span {
font-weight:700;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917activity span span {
color:#ff7900;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917activity span .ygrps-yiv-1235612886yiv0602664917underline {
text-decoration:underline;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 .ygrps-yiv-1235612886yiv0602664917attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 .ygrps-yiv-1235612886yiv0602664917attach div a {
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 .ygrps-yiv-1235612886yiv0602664917attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 .ygrps-yiv-1235612886yiv0602664917attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 .ygrps-yiv-1235612886yiv0602664917attach label a {
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 .ygrps-yiv-1235612886yiv0602664917bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 .ygrps-yiv-1235612886yiv0602664917bold a {
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 dd.ygrps-yiv-1235612886yiv0602664917last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 dd.ygrps-yiv-1235612886yiv0602664917last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 dd.ygrps-yiv-1235612886yiv0602664917last p span.ygrps-yiv-1235612886yiv0602664917yshortcuts {
margin-right:0;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 div.ygrps-yiv-1235612886yiv0602664917attach-table div div a {
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 div.ygrps-yiv-1235612886yiv0602664917attach-table {
width:400px;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 div.ygrps-yiv-1235612886yiv0602664917file-title a, #ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 div.ygrps-yiv-1235612886yiv0602664917file-title a:active, #ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 div.ygrps-yiv-1235612886yiv0602664917file-title a:hover, #ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 div.ygrps-yiv-1235612886yiv0602664917file-title a:visited {
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 div.ygrps-yiv-1235612886yiv0602664917photo-title a, #ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 div.ygrps-yiv-1235612886yiv0602664917photo-title a:active, #ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 div.ygrps-yiv-1235612886yiv0602664917photo-title a:hover, #ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 div.ygrps-yiv-1235612886yiv0602664917photo-title a:visited {
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 div#ygrps-yiv-1235612886yiv0602664917ygrp-mlmsg #ygrps-yiv-1235612886yiv0602664917ygrp-msg p a span.ygrps-yiv-1235612886yiv0602664917yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 .ygrps-yiv-1235612886yiv0602664917green {
color:#628c2a;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 .ygrps-yiv-1235612886yiv0602664917MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 o {
font-size:0;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917photos div {
float:left;width:72px;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917reco-category {
font-size:77%;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917reco-desc {
font-size:77%;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 .ygrps-yiv-1235612886yiv0602664917replbq {
margin:4px;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-mlmsg select, #ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 input, #ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-mlmsg pre, #ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 code {
font:115% monospace;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-mlmsg #ygrps-yiv-1235612886yiv0602664917logo {
padding-bottom:10px;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-msg p#ygrps-yiv-1235612886yiv0602664917attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-reco #ygrps-yiv-1235612886yiv0602664917reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-sponsor #ygrps-yiv-1235612886yiv0602664917ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-sponsor #ygrps-yiv-1235612886yiv0602664917ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-sponsor #ygrps-yiv-1235612886yiv0602664917ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1235612886 #ygrps-yiv-1235612886yiv0602664917 #ygrps-yiv-1235612886yiv0602664917ygrp-vital ul li:last-child {
border-right:none !important;}
