Does anyone know if its possible to change how APM creates its PDF files?
It currently uses a tiff file to produce a PDF this is causing some of our customers issues as they use OCR to read incoming invoices and it cant cope with the single tiff image.
Just wondered if there’s a setting somewhere to change it to the standard PDF format…
Looking at this picture it appears that PDF is TIFF only in version 3.1 as well is that correct because we wont upgrade to this if its only going to do the same format as version 3.0.
Might be a reason to move to SSRS and use Advanced Print Routing.
If I recall, APM just takes a tiff and puts it in a PDF wrapper, it doesn’t actually create a PDF.
