APM Question Blank Title 129546
Here are the code samples I got from my installer. he showed me that it was much easier to edit in wordpad and then paste rather than trying to edit in APM.
check send as html and it looks fine. it will print the placeholder if you don’t have a value for it, so you may have to set a value for a whole paragraph in a script.
HTH
Greg
Body:
Please Confirm receipt and acceptance of Purchase Order {PO #} attached
You may have this PO entered as our reference number {OSAS PO}
Thank you.
{Buyer}
{Buyer Email}
PO Date {Order Date}
SCRIPT TO VALIDATE EMAIL ADDRESS:
If InStr(PropertyValue, "@") <> 0 Then
TextOut = PropertyValue
end if
SCRIPT TO VALIDATE FIELD W/LABEL to LEFT:
If InStr(PropertyValue, "Fax:") <> 0 Then
TextOut = right(PropertyValue, len(PropertyValue) -5)
end if
SCRIPT TO VALIDATE FIELD W/LABEL ABOVE:
dim line
if instr(PropertyValue, "Vendor:") then
  if instr(PropertyValue,chr(10)) then
   line = split(PropertyValue, chr(10))
  TextOut = trim(replace(line(UBound(line)),chr(13),""))
End if
End if
SCRIPT TO VALIDATE FIELD W/LABEL to LEFT and email address:
If InStr(PropertyValue, "Email:") <> 0 Then
PropertyValue = right(PropertyValue, len(PropertyValue) -5)
end if
end if
REMOVE AMPERSAND &
PropertyValue = replace(PropertyValue, "&","AND")
dim line
dim line1
   line1 = trim(replace(line(UBound(line)),chr(13),""))
TextOut = replace(line1, "&","AND")
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of cathy@...
Sent: Friday, April 11, 2014 7:21 PM
Subject: [Vantage] APM Question
What type of control do you have to manage the body of the email?  in Advanced Print Management.
I heard it is cryptic.
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
