I created an Epicor Kinetic UI app and was working on customization layers on top of it. I got an error saving a copy of the layer, and now the app and all layers have disappeared from the Application Studio menu. Where might it have gone? Have there been reports of this?
Iāve been working on my UD101 Entry app. A couple days ago I COULD HAVE SWORN I created a specific event. Yesterday when I got back to work on the project that event was nowhere to be found.
Maybe I just MENTALLY created that event?? Or maybe I DID create it and it got lost in the ether?
For me there wasnāt any errors involved. Just came back the next day and looked for my event for a good 20 minutes completely dumbfounded because I couldāve SWORN I had built it.
I had an application revert to step one of my development before (first dataview and one grid) after working on it for hours and publishing regularly. When i went to move it from test to pilot, I was staring at my beautiful preview in test while the application in both test and pilot had revertedā¦
Grawlix (/ĖÉ”rÉĖlÉŖks/) or obscenicon is the use of typographical symbols to replace profanity, typically using āunpronounceableā characters. Mainly used in cartoons and comics, it has been described as the graphical equivalent of a bleep censor. The first known grawlix appeared in November 1, 1901 story of Gene Carrās comic stripLady Bountiful . (from Wikipedia)
So, hereās a good application for a grawlix. I created the app with the name of the first BAQ instead of the name of the classic dashboard I was re-creating. And then I made seven copies before an incident. And then I couldnāt find my dashboard, because it had the wrong @$%^! name. (See what I did there?)
I copied the wrongly-named app to the right name, exported the wrongly-named layer to a zip file, edited the json file with the right name (37 instances), imported, and tested.
