It’s the darndest thing
I couldn’t figure out why the text boxes were not appearing until I bound them to non UD fields and then they work. They also work unbound.
It gets weirder, sometimes after previewing the page it will shrink the height of the text box to nothing
Bind text box to UD field. Note this field came up as I began to type it in. Epicor supplied the field name. I did not manually type it in. (It is the correct field name)
Preview. Nothing there.
Bind same textbox to non UD field.
It mysteriously starts working.
Set the field back to the original UD fields. Add a second unbound text box to add another field to later. Save and exit application studio
Come back later to work on it and its been flattened
The fields are populated with data. The classic version of this form has been using them for years. No field security on the fields.
The irony is that this very simple customization is to show that we can migrate to Kinetic and it doesn’t even display fields.
I have displayed many UD fields on other forms but this one seems special.
Then again with all the weirdness I have run into with this seemingly unfinished product should I be surprised?
