Applied 708 patch to Version 8.0 and now can't log in
Check clientdrive:\ClientFolder\client\config\default.mfgsys.
For example, mine had the following incorrect line: <AppServerURL value="AppServerDC://\\YourV8Server:3091" />
should've been: <AppServerURL value="AppServerDC://YourV8Server:3091" />
Or check it against the server's version or its backup:
serverdrive:\MfgSys80\client\config\default.mfgsys
serverdrive:\MfgSys80\client\config\backup\default.mfgsys
Epicor uses a search and replace macro to edit these files and I've seen several bad replacements. It can even depend on the patch order, if you skip a patch for example. Also, while some parameters in the client's file can be different, others must match the server's version or it won't let you in..
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Friday, May 13, 2005 3:41 PM
Subject: [Vantage] Applied 708 patch to Version 8.0 and now can't log in
>I applied the 708 patch to our test version of Sonoma because I heard it
> was so great and now I can't log in with my user name, nor the manager
> manager login.
> Has anyone else experienced this? Ben Nixon said he'll write up a doc to
> fix this next week (known issue) but I'm curious as to whether anyone
> else has an answer any sooner than his.
> Sue
> -----Original Message-----
> From: bbelzer42 [mailto:bbelzer@...]
> Sent: Friday, May 13, 2005 2:28 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Selling Shipped Quantity
> That being said, is there anyway to manually adjust those values?
> We have some jobs that close and even though the customer shipment has
> the correct quantity, the "Selling Shipped Quantity" does not update.
> Then, when I close the sales order, I get negative bookings resulting
> from a void sales order. I need to tell the system that we actually
> DID ship the full quantity.
> Any ideas?
> Thanks,
> Ben
> --- In vantage@yahoogroups.com, "Chris Robisch" <blue.wine@v...> wrote:
>> There's SellingJobShippedQty and SellingStockShippedQty. Together,
> they
>> should equal the Shipped Qty.
>> From: "bbelzer42" <bbelzer@t...>
>> Sent: Friday, May 13, 2005 10:10 AM
>> Subject: [Vantage] Selling Shipped Quantity
>> > Can anyone explain this field in the Order Tracker?
>> > It is under Line's Releases in the center.
>> > Sometimes it shows 0 yet we have shipped complete. I can't figure
> out
>> > how vantage calculates this field.
>> > Thanks,
>> > Ben
>> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must
>> > have already linked your email address to a yahoo id to enable
> access. )
>> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder and
>> > Crystal Reports and other 'goodies', please goto:
>> > http://groups.yahoo.com/group/vantage/files/.
> <http://groups.yahoo.com/group/vantage/files/>
>> > (2) To search through old msg's goto:
>> > http://groups.yahoo.com/group/vantage/messages
>> > (3) To view links to Vendors that provide Vantage services goto:
>> > http://groups.yahoo.com/group/vantage/links
>> > Yahoo! Groups Links
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/> .
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
> Yahoo! Groups Links
manager login.
Sue
Any ideas?
Ben
they
out
> > Thanks,
> > Ben
must
access. )
Builder and
> > Yahoo! Groups Links
_____
Yahoo! Groups Links
