Hi all,
I am confused about the hierarchy about labor rate. I just found when I make labor rate in Employee maintenance production info to zero. when I add the time detail in Time and Expense Entry for project. the applied labor is 0. However, I already select a role code and role rate in employee maintenance, project role code sheet and time entry.
So I am curious why system pick zero in employee production info sheet instead of role code rate in project? Thanks.
