Glad to hear it worked.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Chris Robisch
Sent: Saturday, May 26, 2012 4:04 PM
Subject: Re: [Vantage] ApplyDFSql.r
Your's of 5/27/11 worked where mine of 3/4/10 didn't. Thanks, Greg!
This is from my \Epicor905\32\ClientServer directory. I am 64bit SQL, but these should be the 32bit versions. it is dated 5/27/11 My conversion log is in this directory and ClientServer has no files in it, so I believe these are what ran. I was 605 going to 700a and had no issues.
Hope it helps.
Greg
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Chris Robisch
Sent: Saturday, May 26, 2012 9:50 AM
Subject: [Vantage] ApplyDFSql.r
Anyone got a 9.05.700a SQL-Reg-x32 version of ApplyDFSql.r, probably dated 4/16/12, in the Epicor905\ClientServer directory?
Ours wasn't updated going from dvd 9.05.60x to SP 9.05.700 to Patch 9.05.700a. It appears to be the only file not updated but it's the schema change and we're stuck without it. Already reported problem to Epicor. Thanks.
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at (727) 578-6258 and immediately delete the communication.
Hope it helps.
Greg
